[0.8.8] "Chasing" Amy roaming around
What is expected behavior.
After getting to know better Amy with Chasing Amy quest, she should not move from spare bedroom room.
I assume this was done to prevent her from potentially roaming naked around.
But, there is a trick!
After abandoning Scavenger Hunt, if you refuse to sit with Amy near campfire, she is still going there, but "roaming" will not be disabled at that point. Still, going to campfire and talking to her (before she moves to other location), will trigger all things normally done by Chasing Amy quest.
But since not at any point later is roaming change triggered again, in this case she will start roaming after getting to bedroom, after some time. Even if shy and naked.
Proposed fix:
A) Add another roam disable command when she moves first time to bedroom in Chasing Amy
B) Rework a bit whole thing, so you can stop making out in room and Amy is free to roam, until called again
On related note, it is kinda weird that you are unable to suggest Amy to put some clothes, while you are recovering from "intimacy".
Re: [0.8.8] "Chasing" Amy roaming around
peter980 wrote: Sat Feb 17, 2018 8:04 pm What is expected behavior.
Proposed fix:
Hm good catch, will have to look into this thanks! And yes here ending intimacy sequence needs a little touching up.
