Hi guys
I have a problem with Meltdown quest. I had a look everywhere and i couldn't find a solution. Basically I'm stuck in Meltdown quest when we have to fill empty vodka bottle with water. I collected it earlier in game by tricking Frank to leave his spot and steal everything from cabinet. Now I was supossed to inspect the bottle from cabinet and ask Frank if I can take it. After that to use the facet/sink to fill it with water, but as you can see in attached screenshots i'm unable to do it. Is any other solution for it? Any console command to add the bottle of water in inventory? I already tried to add it by console command, but I couldn't find it. I only managed to add washer, whale poster or hammer.
Cheers and sorry if I posted in wrong section
Thank you
Meltdown quest - water bottle
- Untitled2.jpg (306.22 KiB) Viewed 4994 times
- Untitled.jpg (235.38 KiB) Viewed 4994 times
Re: Meltdown quest - water bottle
Same problem.
- Contact:
