I am running into an issue where Ashley keeps approaching me after Julius Squeezer escapes, but will not initiate dialogue. I have tried restarting and loading from an earlier save, but the issue persists. I am currently running 18.2 and have attached a screenshot of the debug menu showing her repeated successful attempts to approach without engaging dialogue.
Has anyone run into this issue? Any recommendations on how to work around it?
Ashley Approach Error
- Debug Console Log Showing Repeated Ashley Approach
- Screenshot (1).png (1.98 MiB) Viewed 6413 times
Re: Ashley Approach Error
Do you have a save file relevant to this that you could attach? Thanks.
I pretty much followed this walkthrough, until this point, where I got stuck:
https://steamcommunity.com/sharedfiles/ ... 1283977160
(Leah, Part 1 is where the snake part is).
Is the snake problem been sorted yet mybruh?
Alright thank you. I'll have to give this a run through and see if I can reproduce it. Did you also save/load exactly where the author instructed you to save/load, or did you follow a more direct path through the non-optional parts of the guide?Maryceusz wrote: ↑Sun Mar 07, 2021 2:03 pmI pretty much followed this walkthrough, until this point, where I got stuck:
I pretty much followed it 100%, but I maybe picked up some items before they were required.erasmus wrote: ↑Wed Mar 10, 2021 10:09 amAlright thank you. I'll have to give this a run through and see if I can reproduce it. Did you also save/load exactly where the author instructed you to save/load, or did you follow a more direct path through the non-optional parts of the guide?Maryceusz wrote: ↑Sun Mar 07, 2021 2:03 pmI pretty much followed this walkthrough, until this point, where I got stuck:
