After the warning i recieved this message:
I tried everything(reinstalling c++redistributable, reinstalling the game) and i cannot figure out what is causing it. I tried it on a virtual machine and it worked.
Runtime error!
Runtime error!
- HouseParty_dyndUxg8QI.png (5.97 KiB) Viewed 7026 times
Re: Runtime error!
On What OS are you playing the game ?
What is the game version you're playing ?
What is the computer locale ?
Could you also provide game's logs ? https://forum.eekllc.com/viewtopic.php?f=7&t=8
Re: Runtime error!
Usually VMs are what cause problems, not fix them... interesting. What are the differences between the physical system and the VM? The issue is likely related.
Re: Runtime error!
Windows 10ttant wrote: ↑Fri May 22, 2020 1:32 pm On What OS are you playing the game ?
0.16.5
I don't know what that means
I attached the output log, i don't have a crashes folder or file
- output_log.txt
- (2.25 KiB) Downloaded 254 times
Re: Runtime error!
I guess it's because of another software, since it worked on the vm and on my previous windows installation.
Re: Runtime error!
Computer locale is the language & region settings used by windows.
https://www.tenforums.com/tutorials/132 ... -10-a.html
Re: Runtime error!
It's us and English (US)ttant wrote: ↑Wed May 27, 2020 11:42 am Computer locale is the language & region settings used by windows.
Re: Runtime error!
What warning exactly ? The fisrt screen when the game starts ?
Re: Runtime error!
Yes, this one
- HouseParty_5PPmZF6VNe.png (532.8 KiB) Viewed 6954 times
Re: Runtime error!
Have you ty without runing the OSD you have in the top left corner ?
As your configuration seems quite ok and you're the only one (i'm aware of) having this issue, i'm wondering if this is not provoked by something else currently running which interfere with the game.
This might be due to a graphic enhencer (like reshade), an antimalware, etc.
