[PROBLEM] Translation does not change in-game
For any and all posts containing House Party translations by our users, discussing the translation system, or reporting issues with translating House Party.
Bug1642
although different here does not change in the game. Just happening in some sentences.
Re: [PROBLEM] Translation does not change in-game
Check the file encoding. it MUST be utf8+bom, otherwise the translation doesn't show up.
Bug1642
So what should I do to fix it?
If it is encoding issue, you have Encoding menu in Notepad++. Use that to change it.
Bug1642
Can I hide the numbers at the beginning?
By number, you mean :
* the line number in the text editor ? in such case, it depends of the text editor, but i guess such option exists.
* the stuff before the | character ? You must NOT touch that, it's the dialog identifier which is use by engine to display the translation instead of the original line.
Bug1642
thanks took care of.
