Version 1.5.0 is out!
Updated to be properly compatible with 0.15.5, by using CSC for 0.15.5.
Also changed placement of some items, thanks to new functionality added in this CSC release.
[Complete Story] Fiery Date [1.2.2.1] {CSC 1.2.2.1}
Re: [Incomplete Story] Fiery Date [0.15.5] {CSC 0.15.5}
None that CSC finally allows teleporting items to different locations in house.
Only limitation is that location needs to be walkto location.
Still, better then old trick when you needed to mount item to some character, teleport character where you want item and then dismount item, hoping it will fall of the ground correctly.
French translation of 1.22.0.
- Fiery Date 1.22.x-fr.zip
- (21.34 KiB) Downloaded 144 times
Version 1.5.1 released
Just re-released with the new CSC version. Should behave exactly as before in the game.
Re: [Incomplete Story] Fiery Date [0.16.5] {CSC 0.15.5}
Version 1.6.0 released
This is a band-aid fix to make the story work with 0.16.5. In the following weeks, when new CSC gets out, I will look into making it work better.
The biggest issue currently is a short loop during intimacy scenes that I need to fix.
Re: [Incomplete Story] Fiery Date [0.16.5] {CSC 0.16.5}
Version 1.7.0 released
Story is now properly updated to 0.16.5.
This includes fix for animation loop issue, which required changing a bit fire shield effect during intimacy.
Since this story is getting hammered in user ratings in Custom Story Brower, please let me know here why do you not like it.
And if you do like it, let it be known by rating it.
Version 1.7.1 released
Fixed issue when "catch" would not be registered if done too quickly.
You should still not be able to do catch more than once per teleport.
didnt workfor me...
i start the quest, then i catch her once, she lost her pant. but then, she continu the game but i cant catch her anymore, no more "catch" option. :/
You need to be at close range to her. About half of maximal range that shows action wheel.
