HELP Having no luck with clothing console commands
roodle
I've checked several different websites, used tons of different kinds of syntax, but the clothing command simply does not seem to work.
I can't even get the help command to show any information.
"help clothing" simply returns couldn't find a valid command from the input.
Every syntax I've tried returns the same.
Examples I've tried;
clothing amy change all off
clothing madison 0 off 0
clothing all all off 0
Not a single one works. All simply return "couldn't find a valid command from the input"
Re: HELP Having no luck with clothing console commands
They changed the way the console commands work. Try typing: Help.v2
Bookebster
chimneyfish wrote: Thu Apr 11, 2024 10:35 am They changed the way the console commands work. Try typing:Help.space bar clicker.v2
I tried but still can't handle it
R3znAv4ts
Most clothing and attributes commands only work on the new v2 console command syntax.
Type help.v2 in the console it will show a list of commands:
change.help < shows how to change clothing.
values.help < for traits/attributes/etc
I just found this on the official Discord.
Google Doc Link : House Party Version 1.3.2.12219 V2 Console Commands Documentation
Credits : @Helix
Edit : Added Google doc link and Creds to @Helix
Shatteredhelix
Just a note, this document isn't entirely complete yet, there are more things that are going to change in the not too distant future and instead of re-doing the entire document, I decided to get it to a state where it was usable and useful. As soon as anything changes, I'll update the document. Also, if you need clarification on anything or if you think something in the document isn't clear enough, please, let me know.
